[GRASS-user] v.segment, v.lrs.create
Markus Neteler neteler at itc.it
Thu Feb 8 12:27:36 EST 2007
On Wed, Feb 07, 2007 at 05:23:28PM +0100, Maciej Sieczka wrote:
> Markus Neteler wrote:
> > Thomas Drüssler wrote on 02/06/2007 09:07 AM:
> >> i'm using grass now for about 3 months now, and i still have some
> >> problems with management of vectors and tables.
> >> now i'm trying to create transects with two meter segments. i
> >> established the transects along several hightlines with v.in.ascii 3d
> >> lines and v.in.ascii 3d points, but now i don't succeed in
> >> establishing the two meter segments.
> > Do you have points and lines as two separate vector maps and want to
> > combine them? Then v.patch and v.clean will be needed.
> Markus,
> Do you mean that this should break lines at points locations? I have
> tried this once, and it didn't work: v.patch points and lines, v.clean
> tool=break didn't break lines at points locations. Or have I
> missunderstood your suggestion?
Mhh, I was hoping for that. Bug or feature?
Markus
