[GRASS-user] pg driver and views
Jarek Jasiewicz
jarekj at amu.edu.pl
Fri Feb 9 12:59:06 EST 2007
Hi all
Tis is not a question, rather remark
I experiment a little with using pg views with grass
generally grass can handle views via db.select and db.execute without
problems and warnings
It is also possible to connect vetor file to view, and use attributes of
view as a labels etc.. It also works in qgis
I add, the view is created from two joined tables!
I can't say nothing about digitising of vector connected with view
becouse I plan to try it soon (first I must prepare view)
Connecting vector with view gives folloowing messages:
Table <widok> does not exist in database <testy>
The table <widok> is now part of vector map <punkty_test> and may be
deleted or overwritten by GRASS modules
DBMI-Postgres driver error:
Cannot create index: // (jj-comment) it is because (kot) is not unique
create unique index widok_kot on widok ( kot )
ERROR: "widok" is not a table
GRASS_INFO_WARNING(5538,3): Cannot create index
GRASS_INFO_WARNING(5538,4): Select privileges were granted on the table
As you can see first grass is "suprised" that something isn't table but
looks similar
Next vector is joined to view as to table: look: grass see the view
as a table!
Next grass "concludes" that "widok" is not the table and returns error,
but vector is joined.
I'm iterested in this so my question is very simple. Is it somewhere
described? (anything about views in grass - simple google query returns
nothing). I only found in help recomendation to use view in v.in.db with
huge tables
regards
Jarek
