[GRASS-user] pg driver and views (long)
    Jarek Jasiewicz
    jarekj at amu.edu.pl
    Sat Feb 10 05:41:10 EST 2007
Markus Neteler napisał(a):
> On Fri, Feb 09, 2007 at 06:59:06PM +0100, Jarek Jasiewicz wrote:
>> Hi all
>> Tis is not a question, rather remark
>> I experiment a little with using pg views with grass
>> generally grass can handle views via db.select and db.execute without
>> problems and warnings
>> It is also possible to connect vetor file to view, and use attributes of
>> view as a labels etc.. It also works in qgis
>> I add, the view is created from two joined tables!
> Please post the command to the list...
> thanks,
> markus
Hi
Here is the detail on what I worked (it is testing work for
demonstration only)
1) I created two postgreSQL tables:
CREATE TABLE profile --data with 5 geological profiles
  cat int2,
  elev int2,
  CONSTRAINT profile_pkey PRIMARY KEY (cat)
WITHOUT OIDS;
CREATE TABLE samples --geological sampels in profiles (25 samples, 5
samples for every profiles)
  id int4,
  pcat int2,
  depth float4,
  caco3 float4,
  res float4,
  sit float4,
  sio float4,
  loi float4
WITH OIDS;
2) Next I created simple vector point layer with five points, with cat
values from 1 to 5, but without table
(it is my way, I rather prefare to create vector and join it with
external table, than use grass form)
3) I created view with following definition. It is very simple view, but
it can be expanded with, for example, WHERE cluase
CREATE OR REPLACE VIEW vinet AS
 SELECT p.cat, avg(s.sit)::float4 AS sit
   FROM samples s
   JOIN profile p ON p.cat = s.pcat
  GROUP BY p.cat;
4) Nex I joined view to vector:
v.db.connect map=vinet driver=pg database=testy table=vinet key=cat layer=1
nd I recived messages (my comments after //)
Table <vinet> does not exist in database <testy> //there is no table
The table <vinet> is now part of vector map <vinet> and may be deleted or overwritten by GRASS modules //table is, and is connected to vector
DBMI-Postgres driver error:
Cannot create index:
create unique index vinet_cat on vinet ( cat )
ERROR:  "vinet" is not a table //something is, but it is not a table
GRASS_INFO_WARNING(7111,3): Cannot create index
GRASS_INFO_WARNING(7111,4): Select privileges were granted on the table //but finally all is OK!
As You can see, grass mesages are contray eachother
5) For the end I tested it with :
v.what -a map=vinet east_north=496736.547013,535807.533363
And I recived, as I expected:
East: 496679.185592
North: 535864.894784
Map: vinet
Mapset: widoki
Point
Layer: 1
Category: 2
driver: pg
database: testy
table: vinet
key column: % //what that???????
cat : 2
sit : 25.44
Addationally:
v.surf.idw input=vinet output=result npoints=12 layer=1 column=sit
End I recived raster map as I expected.
It seems grass can handle postgreSQL views but "he" don't know about it?
So if it can handle views it shall also handle joins respectively?
regards
Jarek
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070210/7b2285b0/attachment.html
