[GRASS-user] r.fillnulls in the latest cvs version doesn't
	work appropriately
    Michael Barton
    michael.barton at asu.edu
    Sat Feb 10 16:36:06 EST 2007
However this gets set, we'll need to change all references in in various
places in the GUI. I hope the g.region flags and options can stabilize soon.
Michael
On 2/10/07 1:29 PM, "Martin Landa" <landa.martin at gmail.com> wrote:
> Hi,
> 2007/2/10, Glynn Clements <glynn at gclements.plus.com>:
> [snip]
>>> I hope I fixed this problem or I missed something? Now:
>>> g.region -m == g.region -gm (== g.region -pgm)
>> Actually, I don't consider -gm => -gpm to be "correct"; what do you
>> use if you *only* want the resolution in metres, and not the region?
> My original idea was to make the -g flag more "universal". It means
> shell-style output used in combination with *other* print flags. This
> cased a lot of problems.
> AFAIK the -m flag is currently the same as the -mg (or now -mgp) flag
> combination. I think it is not the right solution, the -m flag should
> print *only* resolution as Glynn suggests.
> I suppose to start implementing Glynn's proposal from the scratch --
> the print parameter and to supersede the print flags, and in the
> future versions of GRASS remove them. What do you think about it?
>> Explicitly adding -p in r.nulls is preferable, IMHO.
> OK.
> Martin
> [CC: grassdev]
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
