[GRASS-user] edit vector map comments
Sun Feb 11 21:24:55 EST 2007
Wouter wrote:
> what's the easiest way to edit the comments section of vector map (the
> field that shows up with v.info)?
brute force method: edit the text file $MAPSET/vector/$MAPNAME/hist
AFAIK you can put anything there. The raster version of the same
($MAPSET/hist/$MAPNAME) is limited to 80x24 chars however.
Hamish
