[GRASS-user] Re: Query by mouse
Maris Nartiss
maris.gis at gmail.com
Wed Feb 14 02:44:27 EST 2007
it wuold be trivial to add possibility to select multiple maps in
gis.m, but it will need to change every place where one layer is
assumed. This may be too much. Unless somebody provides a working
patch, this should be left for wx GUI.
Aldo Clerici, You can open a wish (featire request) at GRASS bug
tracker so it will not be lost.
Maris.
2007/2/14, Hamish <hamish_nospam at yahoo.com>:
> Aldo Clerici wrote:
> > I'm looking for a way for a multiple query with mouse on GRASS6.2 or
> > 6.3. The Query button in the Map Display of Gis Manager returns the
> > values of the active (highlighted) map only, even if more maps are
> > displayed.
> > The r.what command accessed through Raster > Query by coordinate(s)
> > requires to define the coordinates (even if this is defined as
> > optional) and the mouse can not be used.
> > The d.what.rast (and d.where)can be used in command line mode (lower
> > part of the Output window)but requires the opening of a new external
> > monitor (Otherwise: No graphics device selected).
> > Accidentally I discovered a strange and atypical way for a multiple
> > query. I highligh the name of a map in the map list of the Gis
> > Manager. In the panel 'Display raster maps' I manually insert the
> > names of the other maps to query, separated by commas. At this point
> > the Query button displays the content of all specified maps. This
> > works but doesn't seem a neat solution.
> > Does anybody suggest a better way for a multiple query?
> In an xmon if you overlay multiple raster maps,
> G63> d.mon x0
> G63> d.rast elevation.dem
> G63> d.rast -o slope
> G63> d.rast -o geology
> then d.what.rast will give all three:
> G63> d.what.rast -t
> 594278.69230769:4919478.84615385:1
> elevation.dem at PERMANENT :1554:
> slope at PERMANENT, quant :22:
> slope at PERMANENT, actual :22.878124:23 degrees
> geology at PERMANENT :5:limestone
> The query in gis.m only queries the currenly selected map, even though
> r.what (which it calls) has the capacity to query multiple maps at the
> same time. Your "," trick works from that.
> Another command prompt way using d.where:
> G63> d.where | r.what in=elevation.dem,slope,geology
> Hamish
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
