[GRASS-user] !~: event not found
Glynn Clements
glynn at gclements.plus.com
Thu Feb 15 07:10:22 EST 2007
Hamish wrote:
> > this command gives error
> > d.vect map=jeo2 fcolor=green where="label~'CAMURTASI' and label !~ 'KUMTASI'" type=area
> > bash: !~: event not found
> > But it works in psql side
> > what is the alternative of "!~" in grass ?
> "" quoting does not stop bash from expanding $VAR and ! events.
> Usually you would use '!' for that, but in this case ....
> try
> where="label~'CAMURTASI' and label "'!'"~ 'KUMTASI'"
> ? but there's probably a better way..
If you don't use history expansion, "set +H" turns it off.
