Hamish wrote: > Miguel Correia wrote: >> Why v.patch doesn't create automatically a dbf table? I'm using >> v.6.1version (cygwin). > Because for the DB patch to work, the two dbf table definitions must be > exact. IIUC newer versions of GRASS will attempt to combine the tables. Yes, if you use -e switch. Maciek
