[GRASS-user] d.m.tcl
    Michael Barton
    michael.barton at asu.edu
    Sat Feb 17 23:15:36 EST 2007
Martin,
"d.m" is a script that calls the old x11 display based TclTk GUI. It is no
longer supported, though it still ships with the default GRASS build for
backward compatibility and because some people prefer it.
The current GUI uses TclTk displays and has many more display controls than
the old one. It should be called automatically when you open GRASS. If not,
you can start it with by calling the script gis.m & from the command line
instead of d.m &.
(Note that I follow either command with an ampersand "&". This is so that
either GUI will run and NOT tie up the GRASS command line, leaving it open
for you to issue other commands if you want.).
Michael
On 2/16/07 10:36 AM, "Martin Rutzinger" <Martin.Rutzinger at uibk.ac.at> wrote:
> hi list,
> im working on a fc6 and a fc5 machine and installed them from scratch with the
> newest grass63-cvs. if i try to start the display manager i get the following
> error (see below). furthermore g.copy doesn't work for raster maps
> ('Speicherzugriffsfehler'; should be something like 'memory access error').
> i suppose i have any problem with tcl/tk or gdal, or a missing link... but i
> tried both: tcl/tk8.4 and tcl/tk8.5; gdal-1.3.2 and gdal-1.4.0
> thanks for helping,
> martin
> GRASS 6.3.cvs (utm):~ > d.m
> GRASS 6.3.cvs (utm):~ > Error in startup script:
> Fehler: Benötigter Parameter <output> ist nicht gesetzt:
>     (PostScript Ausgabedatei).
> Beschreibung:
>  Werkzeug zur Erstellung von Ausgabekarten im PostScript-Format.
> Schlüsselwörter:
>  Postscript, Karte, Drucken
> Benutzung:
>  ps.map [-rpe] [input=string] output=string [scale=mapscale]
>    [copies=value] [--verbose] [--quiet]
> Flags:
>   -r   Rotiere Zeichnung um 90 Grad
>   -p   Gebe Papierformate aus (Name Breite Höhe links rechts oben unten(Rand)
>   -e   Erzeugt EPS (Encapsulated PostScript) anstatt PostScript-Dateien.
>  --v   Gesprächige Modulausgabe (verbose)
>  --q   Schweigsame Modulausgabe
> Parameter:
>    input   Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen
> Sie
> input=- für eine interaktive Eingabe über die Tastatur).
>   output   PostScript Ausgabedatei
>    scale   Maßstab der Ausgabekarte, z.B. 1:25000 (standardmäßig: Anpassung an
> die Seite)
>   copies   Anzahl der Kopien.
>            Optionen: 1-20
>     while executing
> "exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
> "DmPrint::init"
>     (procedure "main" line 34)
>     invoked from within
> "main $argc $argv"
>     (file "/usr/local/grass-6.3.cvs/etc/dm/d.m.tcl" line 1637)
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
