[GRASS-user] importing vmap1 data
Markus Neteler neteler at itc.it
Tue Feb 20 04:22:22 EST 2007
Yves Jacolin wrote on 02/19/2007 02:34 PM:
> Le Lundi 19 Février 2007 14:10, Jaime Carrera a écrit :
>> Hi list,
>> Does somebody know how to import vmap1 data in GRASS?
>> Thanks,
>> Jaime
> Hi,
> First of all, you need to install gdal with the OGDI format support (not build
> by default), so you probably need to build your own gdal-ogr command.
> Then you can run :
> ogr2ogr contourl.shp gltp:/vrf/mnt/data/v0eur/vmaplv0/eurnasia
> “contourl at elev(*)_line”
> to convert vmap to shapefile. Avoid to mix upper and lower case in your path !
> Then you can import them into GRASS.
An (untested) alternative might be to get the FWtools which ship with
OGDI driver
and convert to SHAPE or whatever there. Then v.in.ogr to import.
http://fwtools.maptools.org/
Markus
