[GRASS-user] Navicat PostGRESQL and MYSQL
Andreas Neumann neumann at karto.baug.ethz.ch
Sun Feb 25 07:14:44 EST 2007
Hi Kurt,
Yes, PostgreSQL/Postgis is definitely more powerful and tested for
geographic data than MySQL and SQLite. Also PGAdminIII is a good piece
of software. There is an installer for PgadminIII for OSX which runs
withouth problem.
I did a PostgreSQL/Postgis install on OSX (compiled from source) several
times, following the instructions here:
http://www.faqs.org/docs/ppbook/x486.htm - although this is written for
version 7 of Postgresql, the procedure is still the same. Here is also
an installation tutorial:
http://www.postgresql.org/docs/8.2/interactive/install-short.html It
requires the Unix development tools (which you can install from the
Apple Developers CD) and some Unix knowhow, but other than that its a
step by step thing. I didn't have problems with it.
After installing, be sure to allow network access from other computers
by following the instructions here:
http://www.postgresql.org/docs/8.2/interactive/runtime-config-connection.html#RUNTIME-CONFIG-CONNECTION-SETTINGS
(postgresql.conf)
and here (pg_hba.conf):
http://www.postgresql.org/docs/8.2/interactive/client-authentication.html
Hope this helps,
Andreas
Kurt Springs wrote:
> Thanks everyone who answered.  Because of its reputed power in GIS I
> would opt for PostGRESQL with PostGIS and an pgadmin front end.
> However I have had trouble in the past trying to install PostGRESQL
> and could never get it quite right.  I use a Mac with OS X, and it
> requires me to open two accounts on the operating system, and even
> following written directions to the letter, it never came out useable
> and all I ended up doing is taking up space on my hard drive to no
> useful purpose.  Has anyone else had a similar experience and found
> away around these problems?  I wish I could describe what was said,
> but it was some years ago.  After that experience I had been
> reluctant to try again.
> Is MYSQL any easier to install?  Also, has anyone had success with
> SQL Lite Browser?
> Thanks for the advice.
> Kurt
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Andreas Neumann
Institute of Cartography
ETH Zurich
Wolfgang-Paulistrasse 15
CH-8093  Zurich, Switzerland
Phone: ++41-44-633 3031, Fax: ++41-44-633 1153
e-mail: neumann at karto.baug.ethz.ch
www: http://www.carto.net/neumann/
SVG.Open: http://www.svgopen.org/
Carto.net: http://www.carto.net/
