[GRASS-user] COGO along a slope
    Manuel Gimond
    mgimond at colby.edu
    Mon Feb 26 15:13:45 EST 2007
Is there a module (or an easy solution) that will generate line
features from along-terrain COGO data and a DEM?
m.cogo will generate [X,Y] values from COGO data, but it assumes that
the COGO distance measurements have been projected onto a horizontal
surface. The only work around I can think of requires computing slope
data (from a DEM for instance) to get at an average cosine of the
slope underlying each COGO line segment, then correct the COGO
distance to get its projected counterpart. For instance, an
along-terrain distance on a 45 degree slope of 100.0 meters should
translate to a distance of 70.7 meters on a projected plane. This
correction can be tedious if manually computed by hand (especially
since multiple iterations may be needed to compute the average slope
along a line segment). Any ideas?
Cheers,
Manny
