[GRASS-user] replacing cat values of a vector map with another
    Maciej Sieczka
    tutey at o2.pl
    Tue Jan  2 11:08:49 EST 2007
Jachym Cepicky wrote:
> Hi,
> I would like to add this to v.edit something like
> v.edit map=soils cat=10 coords=5000,4000
> set cat of vector feature on coordinates 5000,4000 to 10
> what do you think?
Not sure. How will this work for lines/boundaries? Would one need to
specify line's vertex coordinates? In crossing lines and common
boundaries there are shared vertices (nodes) - what then?
What with points and lines over areas? Or would only the centroid
location = area feature location?
Thanks for developing v.edit. It's a power tool.
Cheers,
Maciek
