[GRASS-user] problem with vi.in.ogr
    Jarek Jasiewicz
    jarekj at amu.edu.pl
    Sat Jan  6 11:58:11 EST 2007
Hi!
cvs from 23.12.2006:
location is set on EPSG 2174 (Polish 1965 zone 4)
when I try import shape with points to location:
v.in.ogr -o dsn=/home/jarekj/shp/PunktyAZP.shp output=azp min_area=0.0001
snap=-1 --overwrite
I recive message:
No projection name! Projection parameters likely to be meaningless.
A datum name S-42 (Pulkovo_1942) was specified without transformation
parameters.
Non-interactive mode: the GRASS default for S-42 is
towgs84=28.000,-130.000,-95.000.
Over-riding projection check.
Proceeding with import...
The vector 'azp' already exists and will be overwritten.
Layer: PunktyAZP
GRASS_INFO_MESSAGE(5079,5): Importing map 3706 features...
Building topology ...
Registering lines: v.in.ogr: split_q.c:65: RTreeClassify: Assertion
`!p->taken[i]' failed.
of course, the last line two lines are imported
table in databese has been created without problems
I add, that I have import lot of shapefiles to that location and problem never
occur
the shape file can  be easily opended and edited in qgis on the same machine
regards\
Jarek
