[GRASS-user] problem with vi.in.ogr
jarekj at amu.edu.pl
Sun Jan 7 15:00:38 EST 2007
7
>All works - for me.
>Maybe your shapefile is corrupted somehow? Can you send it for testing?
probably is, I will test it when I will on computer with ESRI (in
university)
next I will send it to you.
It is nto a problem with projection et all I import several similar
files, but only that one has an error
Adationally I import that shape to Postgis (without problems) but postgis
layer cannot be imported neither to grass (no geometry!) nor QGIS
(MPoints not supperted), when I try open that postgis layer QGIS crash.
