[GRASS-user] Wrong color display for shortest path in GRASS. bug?
Glynn Clements
glynn at gclements.plus.com
Tue Jan 9 15:32:09 EST 2007
Glynn Clements wrote:
> > I find the wrong highlight color of shortest path, when I run shortest
> > path(visualization) (i.e. Vector-> Network Analysis-> shortest
> > route(visualization).
> > I am using GRASS 6.1.cvs obtained from
> > http://geni.ath.cx/grass.html#toc5.
> > If I don't specify the color parameter(hcolor), the default is red;
> > however, it displays black color. When I specifiy the color(hcolor) to
> > be green, it displays red(as screen dumps attached). Do you have the
> > same problem? Is it bug for the GRASS?
> It's a bug; d.path is trying to set the colours while not connected to
> the monitor.
> I'll look into this.
Fixed in CVS.
