[GRASS-user] gis.m: file ppm not found
Agustin Diez Castillo Agustin.Diez at uv.es
Fri Jan 12 06:24:00 EST 2007
Hi all,
I've found the same problem after compiling the January 6 snapshot in
a ppc Mac with XCode provided by www.kyngchaos.com. In my case the
same mapsets work with Grass6.2 and the latest 6.3 binary from the
www.kyngchaos.com.
Agustin
> Since this works with Spearfish but not with some other locations,
my first
> suspect would be a permissions problem.
> To do the graphic display, the GUI needs to send d.* output to
*.ppm files
> in .../$MAPSET/tmp/[userpid] -- whatever is specified by g.tempfile.
> If there are permission problems, this would not work.
> Another potential problem might be with the GRASS environmental
variables
> that set the output to a PPM file rather than an xdisplay.
> Michael
> On 1/11/07 7:51 AM, "Martin Wegmann" <wegmann at biozentrum.uni-
wuerzburg.de>
> wrote:
> > Hello,
> > I did a GRASS 6.3 cvs update one hour ago and now I cannot
display maps
> > (raster/vector) anymore. The error message "file *.ppm not found"
appears.
> > But that happens only in some locations, if I use spearfish it
works fine.
> > BTW I can display my maps via d.mon-d.rast commands hence I think
it is a
> > gis.m problem.
> > any idea, how to fix this?
> > thanks in advance, Martin
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Dr. Agustín Diez Castillo
Departament de Prehistòria i Arqueologia
Universitat de València    Phone:   +34 963 86 42 42
Avda. Blasco Ibañez, 28   Fax:      +34 963 86 42 34
València 46010
