[GRASS-user] compilation problems with libiconv
Frank Broniewski liste at geo-dienstleistung.de
Wed Jan 17 03:28:52 EST 2007
Thanks alot! Removing the "local" iconv from my system did the trick. I don't
even remember correctly why I installed it, but I suspect problems with the
umn mapserver compilation. Well, doesn't matter anymore. Thanks alot again.
Am Dienstag, 16. Januar 2007 18:55 schrieben Sie:
> Frank Broniewski wrote:
> > I am having some problems compiling grass 6.2.1. There seems to be some
> > issue with iconv on my ubuntu 6.06 system.
> > /home/frank/download/grass/grass-6.2.1/dist.i686-pc-linux-gnu/lib/libgras
> >s_driver.so: undefined reference to `libiconv'
> > collect2: ld gab 1 als Ende-Status zurück
> > make[1]: ***
> > [/home/frank/download/grass/grass-6.2.1/dist.i686-pc-linux-gnu/etc/mon.li
> >st] Fehler 1
> > make[1]: Verlasse
> > Verzeichnis '/home/frank/download/grass/grass-6.2.1/display/d.mon/pgms'
> > iconv is installed in /usr/local/bin, /usr/local/lib and
> > /usr/local/include.
> > Does anybody have a idea what the issue might be? Looking into google and
> > the newsgroups didn't bring anything useful for me so I considered
> > writing this email.
> I strongly suspect that the problem is due to having two incompatible
> iconv implementations on your system. Note that GNU libc has iconv
> built in, so there shouldn't be any reason to have a separate iconv
> implementation installed.
> Depending upon the implementation, iconv_open(), iconv(), and
> iconv_close() can be either functions or macros. If they are macros,
> the actual functions will be called libiconv_open(), libiconv() and
> libiconv_close(). If you end up using the headers from a version which
> uses macros along with a library from a version which doesn't use
> macros, you will get the above error. The implementation in GNU libc
> doesn't use macros.
> The configure script first checks for iconv() with no additional
> libraries. It only checks for additional libraries and or libiconv()
> if the first check fails. If you have GNU libc, the first check will
> succeed, and no additional libraries will be requested (i.e. it won't
> add -liconv when linking).
> However, when compiling, the "#include <iconv.h>" will pick up the
> version in /usr/local/include, which defines iconv() etc as macros
> which call libiconv() etc, but as you aren't linking against libiconv,
> those functions won't be found.
> If you're determined to use a stand-alone libiconv, you will need to
> manually edit the definition of ICONVLIB in include/Make/Platform.make
> to:
> 	ICONVLIB            = -L/usr/local/lib -liconv
> after running configure but before compiling.
> But I recommend that you simply remove the separate libiconv
> implementation from your system. It doesn't provide any functionality
> beyond that already provided by GNU libc.
Softwaredienstleistungen
Frank Broniewski
Cloefstraße 76a
66693 Mettlach
Email: frank at geo-dienstleistung.de
WWW: http://www.geo-dienstleistung.de/
Telefon: 06865 / 911 040
