[GRASS-user] shared access to mapsets
Gerald Nelson gnelson at uiuc.edu
Thu Jan 18 15:58:57 EST 2007
That is an incredible list of things you have to do!!! Jerry
---- Original message ----
>Date: Thu, 18 Jan 2007 20:36:31 +0000
>From: Glynn Clements <glynn at gclements.plus.com>
>Subject: Re: [GRASS-user] shared access to mapsets
>To: Duncan Golicher <dgoliche at sclc.ecosur.mx>
>Cc: grassuser at grass.itc.it, grass-dev at grass.itc.it
>[CC'd to grass-dev]
>Duncan Golicher wrote:
>> Can anyone answer a very simple question. I am running grass6.1 under
>> Cygwin with all my data on an external hard drive. I recently installed
>> grass on a new PC. I now can't enter any of the mapsets I created on the
>> first machine from the second and can only get read access to them from
>> new mapsets. I have a different username on the second PC so I obviously
>> don't have permissions. What I can't find out, after Googling and
>> searching the list, are the steps I should take to change the
>> permissions, or perhaps the username in cygwin, so I can just share the
>> database between the two machines.
>Apart from any access controls implemented by the OS, GRASS itself
>won't let you select a mapset as the current mapset unless you are the
>owner of the mapset directory.
>[This check is disabled on the native Windows version, as the
>functions which it uses aren't present there.]
>Note to developers: I'm starting to think that we should seriously
>reconsider this restriction. Now that the .gislock file is in the
>mapset directory rather than the home directory, is there any point in
>having this check?
>In general, to change the owner of a file under Windows XP Pro (I
>don't know if XP Home is any different), perform the following
>(excessively complex) sequence of steps:
>[The process is complicated by the fact that even an administrator
>cannot "give away" files; you have to permit the intended recipient to
>take ownership, then have the recipient actually take ownership of the
>files.]
>+ Log in using either the account which owns the file or an account
>with administrator privileges.
>+ In Explorer, choose the "Folder Options ..." item from the "Tools"
>menu.
>+ Select the "View" tab in the Folder Options dialog.
>+ Uncheck the "Use simple file sharing (Recommended)" option.
>+ Click "OK".
>+ In Explorer, select the file or directory whose ownership you wish
>to change.
>+ Select the "Properties" option from either the "File" menu or the
>context menu (or Alt+Enter).
>+ Select the "Security" tab (this tab is only available once you have
>disabled simple file sharing as directed above).
>+ Click the "Advanced" button.
>+ The "Permissions" tab should be selected.
>+ Click the "Add..." button.
>+ Enter the name of the user to whom you wish to transfer ownership.
>+ Press OK.
>+ Check the box in the "Take Ownership" row and the "Allow" column.
>+ Press OK.
>+ Check the "Replace permission entries ..." option.
>+ Press OK.
>+ Press OK (for the Properties dialog).
>+ Log in as the user to whom you wish to transfer ownership.
>+ Disable simple file sharing as directed above (this is a per-user
>setting).
>+ Select the mapset directory in Explorer.
>context menu.
>+ Select the "Security" tab.
>+ Select the "Owner" tab.
>+ Select your name from the list.
>+ Check the "Replace owner on subcontainers and objects" option.
>+ Press OK.
>Optional: once you've changed the owner, you can remove the "take
>ownership" permission entry. Also, you can re-enable simple file
>sharing if desired; this will hide the Security tab in the Properties
>dialog.
>Tip: to save having to switch between your normal account and an
>administrative account, create a shortcut to "C:\WINDOWS\explorer.exe"
>with the "Run with different credentials" option enabled (click the
>"Advanced" button in the shortcut's properties dialog). This lets you
>do file management using an administrative account without having to
>switch between logins. A few things don't quite work, e.g.
>notifications (you have to manually refresh the view with F5 whenever
>you change something).
>_______________________________________________
>grassuser mailing list
>http://grass.itc.it/mailman/listinfo/grassuser
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
