[GRASS-user] Re: Newbie: Errors Compiling CVS:grass 6.3 on suse 10.2
Maris Nartiss maris.gis at gmail.com
Fri Jan 19 01:49:41 EST 2007
no error, works as expected. If You want to install any soft from
source to system directories (not your home), You need root
privileges. Thath's the way *nix works.
You have specified GRASS install path to /usr/local and You need to
run "make install" from user who has write permission to /usr/local -
usualy it's root. su/sudo make install should be fine.
WBR,
Maris.
2007/1/19, andrew.haywood at poyry.com <andrew.haywood at poyry.com>:
> Dear All,
> I am having problems compiling the latest weekly 6.3-CVS source code
> snapshot. This is the first time I have tried to compile from source - so
> its definitely me!!!. Things seem to go OK when I run the below script.
> but when I run "make install" i get a number of errors along the lines of
> "ERROR: Mapset permanent - permission denied". I have run the "make
> install" as root. Any suggestions on how to fix this would be greatly
> appreciated.
> cheers
> Andy
> Platform: Linux
> OS: Suse 10.2
> grass ver: grass-6.3.cvs_src_snapshot_2007_01_13
> andrew at linux:~/grass-6.3.cvs_src_snapshot_2007_01_13> CFLAGS="-g -Wall"
> ./configure --with-postgres-includes="/usr/include/pgsql
> /usr/include/pgsql/internal" --with-proj-share=/usr/share/proj
> checking host system type... i686-pc-linux-gnu
> checking for gcc... gcc
> checking whether the C compiler (gcc -g -Wall ) works... yes
> checking whether the C compiler (gcc -g -Wall ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... no
> checking for full floating-point support... yes
> checking for pwd... /bin/pwd
> checking for source directory...
> /home/andrew/grass-6.3.cvs_src_snapshot_2007_01_13
> checking for build directory...
> checking how to build libraries... shared
> checking for ranlib... ranlib
> checking how to run the C preprocessor... gcc -E
> checking if 64bit support is requested... no
> checking if 64bit Sparc VIS support is requested... no
> checking system version (for dynamic loading)... Linux-2.6.18.2-23-default
> checking for dlopen in -ldl... yes
> checking for ar... ar
> checking for SysV... no
> checking for XDriver... socket
> checking for additional include dirs...
> checking for additional library dirs...
> checking for a BSD compatible install... /usr/bin/install -c
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking for bison... bison -y
> checking for env... /etc/bash.bashrc
> checking for perl... /usr/bin/perl
> checking for ANSI C header files... yes
> checking for limits.h... yes
> checking for termio.h... yes
> checking for termios.h... yes
> checking for unistd.h... yes
> checking for values.h... yes
> checking for g2c.h... no
> checking for f2c.h... no
> checking for sys/ioctl.h... yes
> checking for sys/mtio.h... yes
> checking for sys/resource.h... yes
> checking for sys/time.h... yes
> checking for sys/timeb.h... yes
> checking for sys/types.h... yes
> checking for sys/utsname.h... yes
> checking for libintl.h... yes
> checking for iconv.h... yes
> checking for langinfo.h... yes
> checking whether time.h and sys/time.h may both be included... yes
> checking for off_t... yes
> checking for uid_t in sys/types.h... yes
> checking return type of signal handlers... void
> checking for ftime... yes
> checking for gethostname... yes
> checking for gettimeofday... yes
> checking for lseek... yes
> checking for nice... yes
> checking for time... yes
> checking for uname... yes
> checking for seteuid... yes
> checking for setpriority... yes
> checking for setreuid... yes
> checking for setruid... no
> checking for drand48... yes
> checking for putenv... yes
> checking for setenv... yes
> checking for nanosleep... yes
> checking whether setpgrp takes no argument... yes
> checking for W11... no
> checking for X... libraries , headers
> checking for dnet_ntoa in -ldnet... no
> checking for dnet_ntoa in -ldnet_stub... no
> checking for gethostbyname... yes
> checking for connect... yes
> checking for remove... yes
> checking for shmat... yes
> checking for IceConnectionNumber in -lICE... yes
> checking whether to use Curses... yes
> checking for curses.h... yes
> checking curses.h WINDOW structure component... _maxy
> checking for initscr in -lncurses... yes
> checking for keypad in -lncurses... yes
> checking for gtty in -lcompat... no
> checking for gtty in -lbsd-compat... yes
> checking for library containing cuserid... none required
> checking for xdrmem_create... yes
> checking for asprintf... yes
> checking for atan... no
> checking for atan in -lm... yes
> checking for dlsym... no
> checking for dlsym in -ldl... yes
> checking for iconv... yes
> checking for socket... yes
> checking for location of zlib includes...
> checking for zlib.h... yes
> checking for location of zlib library...
> checking for deflate in -lz... yes
> checking for location of External PROJ.4 includes...
> checking for proj_api.h... yes
> checking External PROJ.4 version... 449
> checking for location of External PROJ.4 library...
> checking for pj_get_def in -lproj... yes
> checking for location of External PROJ.4 data files... /usr/share/proj
> checking for /usr/share/proj/epsg... yes
> checking for nad2bin... /usr/bin/nad2bin
> checking whether to use Readline... no
> checking whether to use JPEG... yes
> checking for location of JPEG includes...
> checking for jpeglib.h... yes
> checking for location of JPEG library...
> checking for jpeg_start_compress in -ljpeg... yes
> checking whether to use GDAL... yes
> checking for gdal-config... /usr/bin/gdal-config
> checking whether to use TIFF... yes
> checking for location of TIFF includes...
> checking for tiffio.h... yes
> checking for location of TIFF library...
> checking for TIFFOpen in -ltiff... yes
> checking whether to use PNG... yes
> checking for location of PNG includes...
> checking for png.h... yes
> checking for location of PNG library...
> checking for png_read_image in -lpng... yes
> checking whether to use Tcl/Tk... yes
> checking for location of Tcl/Tk includes...
> checking for tcl.h... yes
> checking for tk.h... yes
> checking Tcl version... 8.4
> checking Tk version... 8.4
> checking for location of Tcl/Tk library...
> checking for Tcl_Init in -ltcl... no
> checking for Tcl_Init in -ltcl8.4... yes
> checking for Tk_MainWindow in -ltk... no
> checking for Tk_MainWindow in -ltk8.4... yes
> checking whether to use PostgreSQL... yes
> checking for location of PostgreSQL includes... /usr/include/pgsql
> checking for libpq-fe.h... yes
> checking for location of PostgreSQL library...
> checking for PQsetdbLogin in -lpq... yes
> checking for PQcmdTuples in -lpq... yes
> checking whether to use MySQL... no
> checking whether to use SQLite... no
> checking whether to use FFMPEG... no
> checking whether to use OpenGL... yes
> checking for location of OpenGL includes...
> checking for GL/gl.h... yes
> checking for GL/glu.h... yes
> checking for location of OpenGL library...
> checking for glBegin in -lGL... yes
> checking for gluBeginCurve in -lGLU... yes
> checking for glXCreatePbuffer... yes
> checking for glXCreateGLXPixmap... yes
> checking whether to use ODBC... no
> checking whether to use FFTW... yes
> checking for location of FFTW includes...
> checking for fftw3.h... no
> checking for fftw.h... yes
> checking for location of FFTW library...
> checking for fftw_execute in -lfftw3... no
> checking for fftwnd_one in -lfftw... no
> checking for fftwnd_one in -ldfftw... yes
> checking whether to use BLAS... no
> checking whether to use LAPACK... no
> checking whether to use Motif... no
> checking whether to use GLw... no
> checking whether to use FreeType... no
> checking whether to use NLS... no
> checking whether to use C++... no
> checking whether to use openDWG... no
> checking if system supports Large Files at all... no
> checking whether to use PYTHON... no
> creating ./config.status
> creating include/Make/Grass.make
> creating include/Make/Platform.make
> creating include/version.h
> creating include/winname.h
> creating swig/perl/Makefile.PL
> creating swig/perl2/make.pl
> creating swig/python/Makefile
> creating grass.pc
> creating include/config.h
> include/config.h is unchanged
> Copying config.status to config.status.i686-pc-linux-gnu
> GRASS is now configured for:  i686-pc-linux-gnu
>  Source directory: /home/andrew/grass-6.3.cvs_src_snapshot_2007_01_13
>  Build directory: /home/andrew/grass-6.3.cvs_src_snapshot_2007_01_13
>  Installation directory:      /usr/local/grass-6.3.cvs
>  Startup script in directory: ${exec_prefix}/bin
>  C compiler:                  gcc -g -Wall
>  C++ compiler:
>  FORTRAN compiler:
>  Building shared libraries:   yes
>  64bit support:               no
>  OpenGL platform:             X11
>   NVIZ:                       yes
>   BLAS support:               no
>   C++ support:                no
>   DWG support:                no
>   FFMPEG support:             no
>   FFTW support:               yes
>   FreeType support:           no
>   GDAL support:               yes
>   GLw support:                no
>   JPEG support:               yes
>   LAPACK support:             no
>   Large File Support (LFS):   no
>   Motif support:              no
>   MySQL support:              no
>   NLS support:                no
>   ODBC support:               no
>   OGR support:                yes
>   OpenGL support:             yes
>   PNG support:                yes
>   PostgreSQL support:         yes
>   Python support:             no
>   Readline support:           no
>   SQLite support:             no
>   Tcl/Tk support:             yes
>   TIFF support:               yes
>   X11 support:                yes
> This email and any files transmitted with it are confidential, may be
> legally privileged and are intended solely for the use of the individual or
> entity to whom they are addressed. If you are not the intended recipient,
> you are hereby notified that any use, distribution, or reproduction of the
> contents of this email is strictly prohibited and may be unlawful. If you
> are not the intended recipient, please notify the sender by return email and
> destroy all copies of the original message including any attachments
> thereto.
> Thank you.
