[GRASS-user] compiling 6.3 cvs on ubuntu 64bit
Glynn Clements
glynn at gclements.plus.com
Sun Jan 21 11:29:04 EST 2007
Malte Halbey-Martin wrote:
> I'm facing a compiling error of the gmath lib. When compiling GRASS
> there appears the following error.
> /grass6/dist.x86_64-unknown-linux-gnu/include/grass/lapack.h:1299:
> Fehler: syntax error before »ftnlen«
Odd. I can't see anything about line 1299 that is significantly
different to any other line in that file.
> This error occurs only on my ubuntu (dapper drake) amd64 bit system.
> On my ubuntu (dapper drake x86) in my office all went fine. I even
> copied the lapack.h from this system but didn't help.
> Any suggestions?
As GRASS doesn't actually need LAPACK/BLAS at present (the functions
which use it aren't themselves used by anything), you can just omit
--with-blas and --with-lapack.
