[GRASS-user] errors in r.le.patch calculations
vaniscotte avanisco at univ-fcomte.fr
Mon Jan 22 12:05:31 EST 2007
When I am runing "r.le.patch" I meet systematically some erroneous
calculations for certain columns of pixels.
This happens while I am using the "moving wondow" calculation for some
attributes  (class of metrics: "a"). Whatever the metric calculated some
vertical bands of the output image are always and abnormaly set to 0.
The problem still arises when I try several moving window parameters
(radius or type) and several version of grass (grass60 or grass61)
Has someone ever met this problem? Is it a simple display problem or a
bug in the imagery calculation?
Thanks for your answer
Amélie Vaniscotte
ÐÏࡱá
