[GRASS-user] ps.map: different locations and one document
possible?
Hamish
hamish_nospam at yahoo.com
Wed Jan 24 19:33:50 EST 2007
> wqual wrote:
> > I successfully created a map using the ps.map-command. However, I
> > need to add another layer (background theme) which is in a
> > different location (but same coordinate system). Is there a way to
> > include this layer in my map using ps.map without having to import
> > it into the current location?
Glynn wrote:
> No, it isn't.
> However, you may be able to combine two PostScript files with e.g.
> Adobe Illustrator, or even by manually inserting the relevant portion
> of the second file into the first (the viability of the latter option
> depends upon how well structured the PostScript code is).
tip:
(for subset country-scale image in image corner with box showing area
of interest)
Create an EPS map with ps.map at the country scale, use "g.region save="
and the ps.map "region" instruction to highlight the zoomed in area of
interest.
Change back to the zoomed-in region and rerun ps.map at the desired
scale, then include and place the EPS file with the ps.map "eps"
instruction.
[related- One day I'll fulfill wish #3389]
Hamish
