[GRASS-user] compiling 6.3 cvs on ubuntu 64bit
Glynn Clements
glynn at gclements.plus.com
Wed Jan 24 21:37:14 EST 2007
Brad Douglas wrote:
> > Does that mean that i.fft and i.fft will not build or work properly
> > using gfortran coming with GCC 4.0.3? Is that an issue only with 64 bit
> > systems?
> It's a GCC issue. If you want i.fft/i.ifft, you need LAPACK/BLAS
> support,
No you don't. i.fft and i.ifft require FFTW, but they don't require
LAPACK/BLAS. Nothing in GRASS currently requires BLAS/LAPACK.
