[GRASS-user] Tobler's hiking function
Glynn Clements
glynn at gclements.plus.com
Thu Jan 25 15:30:47 EST 2007
mlage at usal.es wrote:
> I am trying to express Toblers Hiking Function with r.mapcalc.
> This is the expression that Im trying to apply:
> T = D / (6 exp (-3.5) * abs (S+0.05)))
What do you mean by "6 exp (-3.5)"? "6 ^ (-3.5)" or "6 * e^(-3.5)"?
> T= time to cross the cell
> D=resolution of the cell (in my case 25m)
> S=slope in percent
> Im using it to calculate the time needed to cross a cell through the
> relation between the traveling speed (in Km/hr) and the slope to generate
> a friction surface.
> After creating the slope map, I translated it like this:
> r.mapcalc newmap=(6 exp(-3.5*(abs(slopemap)+0.05)))/0.025
This isn't valid r.mapcalc syntax; if the 6 is supposed to be
multiplied by the result of exp(), you need a "*" in there.
