[GRASS-user] v.to.db problem
temiz
temiz at deprem.gov.tr
Fri Jan 26 13:49:38 EST 2007
when I generate point map from line map as:
--- v.to.points input=e30a2top type=point,line,boundary,centroid
output=nokta1 llayer=1 dmax=100
and to insert x,y coords of those points to db
--- GRASS 6.3.cvs (pro1):~/data > v.to.db map=nokta1 option=coor col=x,y
Updating database ... WARNING: More elements of category 1,
nothing loaded to DB
WARNING: More elements of category 2, nothing loaded to DB
and so on
cat values indicate more than one points then v.to.db does not properly.
I used v.category and generated new categories. It also gives another
errors.
do you have any idea ?
regards
Ahmet Temiz
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
