[GRASS-user] Re: v.buffer creates artefact - bug?
Maris Nartiss
maris.gis at gmail.com
Tue Jan 30 17:44:25 EST 2007
Hi Maciej,
I downloaded provided location and can confirm bug. I get same buffer
as You. Running v.clean or v.build on vector does not change anything.
v.digit fixes problem, as You wrote.
One strange thing - v.info says, that there is one island. I can not
see any such feature in v.digit. Am I missing something?
My system:
GRASS 6.2.1 and 6.3-cvs (~ week old)
Gentoo GNU/Linux on i686 (Intel P4 Celeron M)
GCC 4.1.1
WBR,
Maris.
2007/1/30, Maciej Sieczka <tutey at o2.pl>:
> Markus Neteler wrote:
> > Wolfgang Qual wrote on 01/30/2007 11:18 AM:
> >> I am using GRASS 6.1 CVS and created a buffer around a line theme
> >> using the buffcol and buffer option. The result can be loaded into
> >> QGIS and it looks good, except some strange points (artefacts?). I
> >> could provide a screenshot of this (is there a place on the Wiki for
> >> this purpose?).
> > after offlist communication with Wolfgang this is most likely a QGIS/QT
> > rendering bug as already known from: http://svn.qgis.org/trac/ticket/83
> v.buffer was fixed a lot in last months, mainly by Hamish. Many thanks
> to him! And it works mostly OK these days. I'm saying almost - because
> there is still a strange error that I can reproduce always and Hamish
> cannot, although we are using exactly same data. We asked GRASS Folks
> to try to reproduce that too, but there was no feedback. So let me ask
> you All again:
> 1. Grab the location:
> http://kufaya.googlepages.com/vbuffer_issue.tar.bz2
> There is only one vector 'ditch_1205' in mapset 'ditch'. Please buffer
> it with:
> v.buffer in=ditch_1205 out=ditch_1205_buf4 type=area buffer=4
> 2. Please drop a line in this thread whether your output looks like
> this (OK, Hamish's case):
> http://kufaya.googlepages.com/ditch_1205_edt_b4.png
> or this (bad, my case):
> http://kufaya.googlepages.com/ditch_1205_b4.png
> With any thoughts on what is going on here.
> This will maybe give us some hint why on Earth exactly the same
> command, same v.buffer version and same input data yield different
> results for me and Hamish.
> For me, in order to achieve the same result as Hamish does, I have to
> edit the 'ditch_1205' in v.digit, by disconnecting the snapped boundary
> and connecting it back, like:
> http://kufaya.googlepages.com/ditch_1205_edt1.png
> http://kufaya.googlepages.com/ditch_1205_edt2.png
> http://kufaya.googlepages.com/ditch_1205_edt3.png
> This is nuts, because before and after the "edit" the vector remains
> topologicaly clean and perfectly the same, *besides* the order in which
> boundaries are listed, if you look at the output of 'v.out.ascii
> ditch_1205_edt form=standard' before and after v.digit "session" as
> outlined on the 3 pics above. And the strangest thing is that Hamish
> doesn't need to do this edit for v.buffer to work properly, while I do.
> Please look into the http://intevation.de/rt/webrt?serial_num=2765 for
> details, the message on Sun, Nov 26 2006 22:38:08 especialy.
> Maciek
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
