[GRASS-user] db.execute: SELECT STATEMENT
Jarosław Jasiewicz
jarekj at amu.edu.pl
Wed Jan 31 03:06:00 EST 2007
Wolf Bergenheim napisał(a):
> Jarek Jasiewicz wrote:
>> But what about this (sample test query):
>> echo "UPDATE testpoint_2 SET test=(SELECT max(cat) FROM testpoint_1)
>> WHERE cat IN (SELECT cat FROM testpoint_3 WHERE x>10)" | db.execute
>> it works! AFAIK such quries are treated as both SELECT and UPDATE query!
> Yes it works since it is an 'UPDATE' query. Since it doesn't return a
> list of results. It returns success or fail. A select query is one
> which *begin* with the 'SELECT' statement.
> SELECT something FROM sometingelse WHERE ...
> --Wolf
So that means that "problem" is only in documentation
regards
Jarek
