[GRASS-user] loss of attribute precision when using v.extract
roelof burger
roelof.burger at gmail.com
Tue Jul 3 11:26:10 EDT 2007
Dear Grass users,
Is there any way I can get around the following:
I have a vector layer with attached column:
column:CODE
type: DOUBLE PRECISION
len: 20
scale: 6
precision: 18
default:
nullok:yes
select:yes
update:yes
it varies between 1.0101e+10 and 9.9605e+10 (ie 21131001001)
I extract a portion of the vector with the following command looking
at a different column:
v.extract input=MYVECTOR output=OUTPUTVECTOR where='CODE2=400'
this extracts the vector correctly, but if I look at the columns
attached to the vector, I get the following:
column:CODE
len: 20
scale: 6
precision: 18
default:
nullok:yes
select:yes
update:yes
but now the values are stuck at 2147483647.
Any help would be much appreciated,
Regards,
Roelof
