[GRASS-user] r.region
Michael Perdue michael_perdue at yahoo.ca
Tue Jul 3 18:08:20 EDT 2007
The simplest way to reproject a bunch of tiff files into a new
projection is to use gdalwarp in a loop. Something like,
for i in `ls *.tif  |  awk 'BEGIN {FS="."} ; {print $1} '`; do
	gdalwarp s_srs epsg:26910 t_srs epsg:2766 $i.tif $i_spcs-
CaliforniaZone1.tif
done
You'll have to play with the syntax as I don't use it very often but
this example should transform all the tiff files in the local
directory from epsg:26910 (NAD83 UTM10) to epsg:2766 (SPCS NAD83
California zone 1).
Cheers,
Mike
On 3-Jul-07, at 3:11 PM, goldneaa at onid.orst.edu wrote:
> If I have about 800 raster files in tiff format that are in the
> wrong projection.  Is there a way to change their coordinate
> systems all at once.  After examining r.region it seems to only
> want to change one raster at a time.  Will I have to build a
> command in unix, in order to change these rasters projections?
> Thanks
> Aaron
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070703/182fcfbd/attachment.html
