[GRASS-user] r.region
Tue Jul 3 22:01:22 EDT 2007
Maciej Sieczka wrote:
> goldneaa wrote:
> > If I have about 800 raster files in tiff format that are in the
> > wrong projection.  Is there a way to change their coordinate systems
> > all at once.  After examining r.region it seems to only want to
> > change one raster at a time.  Will I have to build a command in
> > unix, in order to change these rasters projections?
> r.region is not for changing raster's projection. It only moves and
> rescales it in space, by setting "the boundary definitions for a
> raster map".
> If you want to reproject, use r.proj instead.
> As to multiple raster input - in shell you could use something like:
> for i in `g.list rast mapset=some_mapset | grep string_common_for_all_rasters_you_want_included`
> do
>  r.some.command input=${i} output=${i}_suffix
> done
> Mind that g.list always prints a few extra lines of text at the top
> and the bottom of it's output,
> BTW - it would be really nice IMHO to have a "Print in shell script
> style" option in g.list, ie. no extra text, one name per line.
Use g.mlist.
for MAP in `g.mlist rast` ; do
  r.info -r $MAP
done
Michael Perdue wrote:
> The simplest way to reproject a bunch of tiff files into a new
> projection is to use gdalwarp in a loop. Something like,
> for i in `ls *.tif |   [...]
beware that the max command line string may be 4096 chars, and 800 maps
could fill that. ("basename $file .tif" in the `command` part could help
conserve 4 chars per map)
back to the original question:
> If I have about 800 raster files in tiff format that are in the wrong
> projection.  Is there a way to change their coordinate systems all at
> once.
As the input is TIFF, probably the easy way is to use GDAL tools,
specifically gdalwarp and/or gdal_translate to make a new GeoTIFF in the
target projection.
Hamish
