[GRASS-user] converting contour lines to points
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Wed Jul 4 08:29:01 EDT 2007
Well, this seems to work.
Thanks, Maciek.
Maciej Sieczka wrote:
> Benjamin Ducke wrote:
>> OK, here is mine ;)
>> I would like to break up a map of contour lines into points. Since
>> contour lines are essentially just a bunch of nodes with arcs
>> connecting them, I thought it should be straight-forward to
>> decompose them. However, v.type refuses to do a line->points
>> conversion and v.to.points creates new points along the lines
> Not necessarily; from the manual:
> "The -v flag is used to digitize points that fall on the line's
> vertices only. dmax is ignored in this case."
> Is that what you need?
> Maciek
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
