[GRASS-user] atan() in r.mapcalc
    Glynn Clements
    glynn at gclements.plus.com
    Wed Jul  4 11:30:58 EDT 2007
"Carlos \"Guâno\" Grohmann" wrote:
> from the man page:
> atan(x,y)               inverse tangent of y/x (result is in degrees)
> is this correct? is it y/x or x/y?
The documentation is correct. When r.mapcalc's atan() function is
passed two arguments, it calls the ANSI C atan2() function with the
arguments swapped, then converts the result from -PI..PI radians to
0..360 degrees:
	res[i] = RADIANS_TO_DEGREES * atan2(arg2[i], arg1[i]);
	if (res[i] < 0)
		res[i] += 360.0;
The different argument order may be confusing, but changing it would
break existing scripts.
