[GRASS-user] Problem with v.out.dxf
Martin Landa landa.martin at gmail.com
Fri Jul 6 08:06:01 EDT 2007
06 Jul 2007 11:49:48 +0100, S. Merlo <sm399 at cam.ac.uk>:
> Thanks Martin for prompt reply.
> What happens when I run the command from the terminal is copied below. No
> file is created in the folder.
>  v.out.dxf input=tindxf806 output=tindxf806_4.dxf
>  100%
Hm, strange, maybe debug output helps to identify the problem...
g.gisenv set=DEBUG=5
or
v.out.dxf input=tindxf806 output=tindxf806_4.dxf 2>debug.txt
Martin
> stefania
> On Jul 6 2007, Martin Landa wrote:
> >Hi,
> >06 Jul 2007 11:25:20 +0100, S. Merlo <sm399 at cam.ac.uk>:
> >> Dear Grass users,
> >> I have been using with success grass 6.2.1-3 on Linux pc039
> >> 2.6.20-16-generic. I am experiencing problems exporting GRASS vector
> >> files to dxf format (v.out.dxf). I launch the command and the output
> >> monitor progress bar freezes at the very beginning. The file name is
> >> created in PERMANENT but it contains nothing. Is this a bug or am I
> >> doing something wrong? I would really appreciate some help.
> > Can you reproduce this behaviour via command line? E.g. in "Spearfish"
> > location:
> >v.out.dxf in=roads out=roads.dxf
> >Martin
> Stefania Merlo
> Department of Archaeology
> University of Cambridge
> United Kingdom
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
