[GRASS-user] Problem with v.out.dxf
Martin Landa
landa.martin at gmail.com
Fri Jul 6 10:17:07 EDT 2007
... anyway I din't find anything wrong in the debug output ...
Martin
2007/7/6, Martin Landa <landa.martin at gmail.com>:
> Stefania,
> this is really whole debug output, anything is not missing? Are you
> able to send (me) any testing data?
> Martin
> 06 Jul 2007 15:09:10 +0100, S. Merlo <sm399 at cam.ac.uk>:
> > Hi. This is the message I get on screen. Sorry, but i do not have the
> > ability of understanding what is going on.
> > Help appreciated.
> > stefania
> > D3/5: off = 4599
> > D3/5: Vect_read_line()
> > D3/5: V2_read_line_nat(): line = 126
> > D3/5: Vect__Read_line_nat: offset = 4599
> > D3/5: type = 8, do_cats = 1 dead = 0
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4628
> > D3/5: V2_read_line_nat(): line = 127
> > D3/5: Vect__Read_line_nat: offset = 4628
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4657
> > D3/5: V2_read_line_nat(): line = 128
> > D3/5: Vect__Read_line_nat: offset = 4657
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4686
> > D3/5: V2_read_line_nat(): line = 129
> > D3/5: Vect__Read_line_nat: offset = 4686
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4715
> > D3/5: V2_read_line_nat(): line = 130
> > D3/5: Vect__Read_line_nat: offset = 4715
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4744
> > D3/5: V2_read_line_nat(): line = 131
> > D3/5: Vect__Read_line_nat: offset = 4744
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4773
> > D3/5: V2_read_line_nat(): line = 132
> > D3/5: Vect__Read_line_nat: offset = 4773
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4802
> > D3/5: V2_read_line_nat(): line = 133
> > D3/5: Vect__Read_line_nat: offset = 4802
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4831
> > D3/5: V2_read_line_nat(): line = 134
> > D3/5: Vect__Read_line_nat: offset = 4831
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4860
> > D3/5: V2_read_line_nat(): line = 135
> > D3/5: Vect__Read_line_nat: offset = 4860
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4889
> > D3/5: V2_read_line_nat(): line = 136
> > D3/5: Vect__Read_line_nat: offset = 4889
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4918
> > D3/5: V2_read_line_nat(): line = 137
> > D3/5: Vect__Read_line_nat: offset = 4918
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4947
> > D3/5: V2_read_line_nat(): line = 138
> > D3/5: Vect__Read_line_nat: offset = 4947
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 4976
> > D3/5: V2_read_line_nat(): line = 139
> > D3/5: Vect__Read_line_nat: offset = 4976
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5005
> > D3/5: V2_read_line_nat(): line = 140
> > D3/5: Vect__Read_line_nat: offset = 5005
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5034
> > D3/5: V2_read_line_nat(): line = 141
> > D3/5: Vect__Read_line_nat: offset = 5034
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5063
> > D3/5: V2_read_line_nat(): line = 142
> > D3/5: Vect__Read_line_nat: offset = 5063
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5092
> > D3/5: V2_read_line_nat(): line = 143
> > D3/5: Vect__Read_line_nat: offset = 5092
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5121
> > D3/5: V2_read_line_nat(): line = 144
> > D3/5: Vect__Read_line_nat: offset = 5121
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5150
> > D3/5: V2_read_line_nat(): line = 145
> > D3/5: Vect__Read_line_nat: offset = 5150
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5179
> > D3/5: V2_read_line_nat(): line = 146
> > D3/5: Vect__Read_line_nat: offset = 5179
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5208
> > D3/5: V2_read_line_nat(): line = 147
> > D3/5: Vect__Read_line_nat: offset = 5208
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5237
> > D3/5: V2_read_line_nat(): line = 148
> > D3/5: Vect__Read_line_nat: offset = 5237
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5266
> > D3/5: V2_read_line_nat(): line = 149
> > D3/5: Vect__Read_line_nat: offset = 5266
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5295
> > D3/5: V2_read_line_nat(): line = 150
> > D3/5: Vect__Read_line_nat: offset = 5295
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5324
> > D3/5: V2_read_line_nat(): line = 151
> > D3/5: Vect__Read_line_nat: offset = 5324
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5353
> > D3/5: V2_read_line_nat(): line = 152
> > D3/5: Vect__Read_line_nat: offset = 5353
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5382
> > D3/5: V2_read_line_nat(): line = 153
> > D3/5: Vect__Read_line_nat: offset = 5382
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5411
> > D3/5: V2_read_line_nat(): line = 154
> > D3/5: Vect__Read_line_nat: offset = 5411
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5440
> > D3/5: V2_read_line_nat(): line = 155
> > D3/5: Vect__Read_line_nat: offset = 5440
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5469
> > D3/5: V2_read_line_nat(): line = 156
> > D3/5: Vect__Read_line_nat: offset = 5469
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5498
> > D3/5: V2_read_line_nat(): line = 157
> > D3/5: Vect__Read_line_nat: offset = 5498
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5527
> > D3/5: V2_read_line_nat(): line = 158
> > D3/5: Vect__Read_line_nat: offset = 5527
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5556
> > D3/5: V2_read_line_nat(): line = 159
> > D3/5: Vect__Read_line_nat: offset = 5556
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5585
> > D3/5: V2_read_line_nat(): line = 160
> > D3/5: Vect__Read_line_nat: offset = 5585
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5614
> > D3/5: V2_read_line_nat(): line = 161
> > D3/5: Vect__Read_line_nat: offset = 5614
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5643
> > D3/5: V2_read_line_nat(): line = 162
> > D3/5: Vect__Read_line_nat: offset = 5643
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5672
> > D3/5: V2_read_line_nat(): line = 163
> > D3/5: Vect__Read_line_nat: offset = 5672
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5701
> > D3/5: V2_read_line_nat(): line = 164
> > D3/5: Vect__Read_line_nat: offset = 5701
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5730
> > D3/5: V2_read_line_nat(): line = 165
> > D3/5: Vect__Read_line_nat: offset = 5730
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5759
> > D3/5: V2_read_line_nat(): line = 166
> > D3/5: Vect__Read_line_nat: offset = 5759
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5788
> > D3/5: V2_read_line_nat(): line = 167
> > D3/5: Vect__Read_line_nat: offset = 5788
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5817
> > D3/5: V2_read_line_nat(): line = 168
> > D3/5: Vect__Read_line_nat: offset = 5817
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5846
> > D3/5: V2_read_line_nat(): line = 169
> > D3/5: Vect__Read_line_nat: offset = 5846
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5875
> > D3/5: V2_read_line_nat(): line = 170
> > D3/5: Vect__Read_line_nat: offset = 5875
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5904
> > D3/5: V2_read_line_nat(): line = 171
> > D3/5: Vect__Read_line_nat: offset = 5904
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5933
> > D3/5: V2_read_line_nat(): line = 172
> > D3/5: Vect__Read_line_nat: offset = 5933
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5962
> > D3/5: V2_read_line_nat(): line = 173
> > D3/5: Vect__Read_line_nat: offset = 5962
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 5991
> > D3/5: V2_read_line_nat(): line = 174
> > D3/5: Vect__Read_line_nat: offset = 5991
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6020
> > D3/5: V2_read_line_nat(): line = 175
> > D3/5: Vect__Read_line_nat: offset = 6020
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6049
> > D3/5: V2_read_line_nat(): line = 176
> > D3/5: Vect__Read_line_nat: offset = 6049
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6078
> > D3/5: V2_read_line_nat(): line = 177
> > D3/5: Vect__Read_line_nat: offset = 6078
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6107
> > D3/5: V2_read_line_nat(): line = 178
> > D3/5: Vect__Read_line_nat: offset = 6107
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6136
> > D3/5: V2_read_line_nat(): line = 179
> > D3/5: Vect__Read_line_nat: offset = 6136
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6165
> > D3/5: V2_read_line_nat(): line = 180
> > D3/5: Vect__Read_line_nat: offset = 6165
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6194
> > D3/5: V2_read_line_nat(): line = 181
> > D3/5: Vect__Read_line_nat: offset = 6194
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6223
> > D3/5: V2_read_line_nat(): line = 182
> > D3/5: Vect__Read_line_nat: offset = 6223
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6252
> > D3/5: V2_read_line_nat(): line = 183
> > D3/5: Vect__Read_line_nat: offset = 6252
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6281
> > D3/5: V2_read_line_nat(): line = 184
> > D3/5: Vect__Read_line_nat: offset = 6281
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6310
> > D3/5: V2_read_line_nat(): line = 185
> > D3/5: Vect__Read_line_nat: offset = 6310
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6339
> > D3/5: V2_read_line_nat(): line = 186
> > D3/5: Vect__Read_line_nat: offset = 6339
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6368
> > D3/5: V2_read_line_nat(): line = 187
> > D3/5: Vect__Read_line_nat: offset = 6368
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6397
> > D3/5: V2_read_line_nat(): line = 188
> > D3/5: Vect__Read_line_nat: offset = 6397
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6426
> > D3/5: V2_read_line_nat(): line = 189
> > D3/5: Vect__Read_line_nat: offset = 6426
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6455
> > D3/5: V2_read_line_nat(): line = 190
> > D3/5: Vect__Read_line_nat: offset = 6455
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6484
> > D3/5: V2_read_line_nat(): line = 191
> > D3/5: Vect__Read_line_nat: offset = 6484
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6513
> > D3/5: V2_read_line_nat(): line = 192
> > D3/5: Vect__Read_line_nat: offset = 6513
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6542
> > D3/5: V2_read_line_nat(): line = 193
> > D3/5: Vect__Read_line_nat: offset = 6542
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6571
> > D3/5: V2_read_line_nat(): line = 194
> > D3/5: Vect__Read_line_nat: offset = 6571
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6600
> > D3/5: V2_read_line_nat(): line = 195
> > D3/5: Vect__Read_line_nat: offset = 6600
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6629
> > 100%
> > D3/5: V2_read_line_nat(): line = 196
> > D3/5: Vect__Read_line_nat: offset = 6629
> > D3/5: n_cats = 1
> > D3/5: n_points = 1
> > D3/5: off = 6658
> > >Hi,
> > >06 Jul 2007 11:49:48 +0100, S. Merlo <sm399 at cam.ac.uk>:
> > >> Thanks Martin for prompt reply.
> > >> What happens when I run the command from the terminal is copied below. No
> > >> file is created in the folder.
> > >> v.out.dxf input=tindxf806 output=tindxf806_4.dxf
> > >> 100%
> > >Hm, strange, maybe debug output helps to identify the problem...
> > >g.gisenv set=DEBUG=5
> > >or
> > >v.out.dxf input=tindxf806 output=tindxf806_4.dxf 2>debug.txt
> > >Martin
> > >> stefania
> > >> On Jul 6 2007, Martin Landa wrote:
> > >> >Hi,
> > >> >06 Jul 2007 11:25:20 +0100, S. Merlo <sm399 at cam.ac.uk>:
> > >> >> Dear Grass users,
> > >> >> I have been using with success grass 6.2.1-3 on Linux pc039
> > >> >> 2.6.20-16-generic. I am experiencing problems exporting GRASS vector
> > >> >> files to dxf format (v.out.dxf). I launch the command and the output
> > >> >> monitor progress bar freezes at the very beginning. The file name is
> > >> >> created in PERMANENT but it contains nothing. Is this a bug or am I
> > >> >> doing something wrong? I would really appreciate some help.
> > >> > Can you reproduce this behaviour via command line? E.g. in "Spearfish"
> > >> > location:
> > >> >v.out.dxf in=roads out=roads.dxf
> > >> >Martin
> > >> Stefania Merlo
> > >> Department of Archaeology
> > >> University of Cambridge
> > >> United Kingdom
> > Stefania Merlo
> > United Kingdom
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
