[GRASS-user] to shorten lines
Markus Neteler
neteler at itc.it
Sun Jul 8 15:27:01 EDT 2007
ivan marchesini wrote:
> Dear Users...
> I have a vector lines map...
> I would like to shorten each line of the map.... the amount of the
> shortening could be fixed (10 meters.. may be)
> I would like to do this in each part of the line... i.e.:
> old lines:
> ____________
> new lines:
> __________
> any idea about a quick way to solve this problem...???
> thanks...
> Ivan
Hi Ivan,
pseudo-code (for a script or so):
- fetch all vector lengths with v.report
- calculate length - desired shortening (nice SQL excercise)
- use v.segment with
L <segment id> <line cat> <start offset> <end offset>
to create the segments at then end to be removed
- use v.overlay with NOT
cheers
Markus
View this message in context: http://www.nabble.com/to-shorten-lines-tf4045136.html#a11491881
Sent from the Grass - Users mailing list archive at Nabble.com.
