[GRASS-user] Having problems with v.in.ogr
Edward Tomlinson
edwardjtomlinson at gmail.com
Sun Jul 8 22:09:40 EDT 2007
Hi Hamish,
Yes, changing the default grid size fixed my problem. I initially read it as
square meters (or assumed), however when i looked at it again i realised my
mistake. I have been away most of last week so have not had a chance to
progress any further with DEM creation.
As far as making the shapefile available it is around 5mb in size. Also i
dont really have any where to put it except one of the commercial sites.
However i can still make a copy available if you like.
Thanks,
Ed
On 04/07/07, Hamish <hamish_nospam at yahoo.com> wrote:
> Edward Tomlinson wrote:
> > I am having issues importing a shapefile using v.in.ogr
> > Using basic command v.in.ogr dsn=shapefile layer=shapefile name
> > output=elev
> > getting the following areas for every entry
> > GRASS_INFO_WARNING(29..,50..): Area size 6.5e-11, area not imported.
> > [warning sign] area size 6.5e-11, area not imported
> Reduce v.in.ogr's min_area option.
> min_area Minimum size of area to be imported (square units).
> Smaller areas and islands are ignored. Should be
> greater than snap^2
> default: 0.0001
> > THe shapefile was generated by a Greenstar 2 GPS receiver (John
> > Deere).
> could you make a small sample available somewhere?
> > There are many columns in the shapefile (30).
> > How can i limit the number of columns i read in,
> you can't during import, but you can later with v.db.dropcol
> > and how to set which column is the elevation column (or is ELEVATION
> > okay)?
> I am not sure if there is a vector tool to change a 2D vector + numeric
> column into a 3D vector directly.
> v.out.ascii + "v.in.ascii z=" would probably do it.
> but most GRASS DEM creation tools will let you specify a 2D vector + elev
> column name instead of needing a 3D vector as the input.
> > I am assuming it has something to do with the way the shapefile was
> > genereated and the precision/length of the numeric fields in the
> > database???
> As long as the datafile is not corrupt you /should/ be able to work with
> whatever is in it.
> > Also what is a good .dbf viewer for KDE?
> Don't know about KDE, but "dbview -bt" is nice from the command line, and
> OpenOffice is probably ok if there are less than a few tens of thousands
> of
> entries.
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070709/81604261/attachment.html
