[GRASS-user] cvs make problems
Brad Douglas rez at touchofmadness.com
Mon Jul 9 13:31:26 EDT 2007
Try using '-mcpu=athlon64'.  I have a similar system which compiles
fine.  Let me know if you still have problems.
BTW, you don't really need readline.  IIRC, it's only used in r.mapcalc
for command history.
On Mon, 2007-07-09 at 11:16 -0500, Gerald Nelson wrote:
> I have a new computer with an AMD 64 Athlon X2 chip and a gig of ram. I want to install 6.3 cvs with 64 bit support. The steps I have followed (more or less are )
> - cvs update (today)
> - run CFLAGS="-O2 -mcpu=athlon -Wall" LDFLAGS="-s"
> - configure with the options listed below
>  ./configure \
>            --enable-largefile                                    \
>            --with-postgres-includes=/usr/local/pgsql/include/    \
>            --with-proj-includes=/usr/local/include/              \
>            --with-proj-share=/usr/share/proj/                    \
>            --with-postgres-libs=/usr/local/pgsql/lib/            \
>            --with-readline-libs=/usr/local/lib/                  \
>            --with-readline-includes=/usr/local/include/readline/ \
>            --enable-64bit/                                       \
>            --with-libs=/usr/lib64                               \
>            --with-readline=yes
> - make
> The make returns error 1. The first place I can find with a problem (although I haven't dumped the output to a text file is
> Makefile:108: warning: overriding commands for target `clean'
> ../include/Make/Rules.make:34: warning: ignoring old commands for target `clean'
> make[1]: Leaving directory `/usr/local/grass6/macosx'
> if [ 0 -eq 1 ] ; then make -C locale; fi
> cp -f AUTHORS COPYING README REQUIREMENTS.html /usr/local/grass6/dist.x86_64-unknown-linux-gnu/
> cp -f /usr/local/grass6/bin.x86_64-unknown-linux-gnu/grass63 /usr/local/grass6/dist.x86_64-unknown-linux-gnu/grass63.tmp
> build_html_index.sh
> cp: cannot create regular file `../dist.x86_64-unknown-linux-gnu/docs/html/nviz/': Is a directory
> chmod: cannot access `../dist.x86_64-unknown-linux-gnu/docs/html/nviz/grassdocs.css': No such file or directory
> chmod: cannot access `../dist.x86_64-unknown-linux-gnu/docs/html/nviz/grass_logo.png': No such file or directory
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
