[GRASS-user] creating loops in grass
Aaron Racicot
aaronr at z-pulley.com
Mon Jul 9 19:25:26 EDT 2007
Aaron,
The for loop structure for csh and bash are different and it looks like you
are using the bash syntax in a csh environment.
Either:
1) Switch to bash
2) Google foreach loops in csh and modify your syntax
Hope that helps...
A
Aaron Racicot - GIS Programmer
360.221.2441 - aaronr at ecotrust.org
e c o t r u s t
pobox 1614
langley wa 98260
www.ecotrust.org
-----Original Message-----
From: grassuser-bounces at grass.itc.it [mailto:grassuser-bounces at grass.itc.it]
On Behalf Of goldneaa at onid.orst.edu
Sent: Monday, July 09, 2007 3:43 PM
To: grassuser at grass.itc.it
Subject: [GRASS-user] creating loops in grass
I have been using the directions for creatings loops in GRASS, but
have not been able to get a correct script. Below is what i am
inputing and what I am recieving out
Mapset <PERMANENT> in Location <globe_final>
GRASS 6.3.cvs > for raster in `g.mlist rast
pattern="ts_*"` ; do r.info -r $raster done
csh: for: Command not found.
csh: do: Command not found.
I have also tried using the ls function to create a loop and recieved
the output
GRASS 6.3.cvs > for raster in `ls
/Volumes/ar4/gis/globe_final/PERMANENT/hist/ts_*` ; do r.info $raster
done
Any advice for what I can do to fix this problem.
Aaron
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
