[GRASS-user] problem in v.drape command
Tue Jul 10 04:22:42 EDT 2007
> PS: do you think that we should exit after issuing the warning?
If vector z values can be assigned to NULL, I'd suggest G_warning(). If
0 I'd suggest don't write bad data and G_fatal_error() (which calls
exit(EXIT_FAILURE). But I've no experience with the module, so that's
just my 2c.
> If so, is there a G_ function to do that cleanly?
just use G_fatal_error() without G_warning().
> A patch based on this suggestion is attached. I have tested and it
> appears to work.
AFAICT it looks ok, but it is very hard to read:
Please keep indentation and code patches separate. It makes it very hard
to see real changes in the .diff. See SUBMITTING rule #15. Also please
follow the suggested indent rules for new code. (indent level of 4,
tabstop of 8, max line length 80 chars)
indent codes explained:
 http://grass.gdf-hannover.de/wiki/Development#Explanation_of_C_indentation_rules
thanks,
Hamish
