[GRASS-user] csh syntax
goldneaa at onid.orst.edu
Thu Jul 12 10:57:13 EDT 2007
I found the bash command for adding up rasters as
$str="r.mapcalc map=ts.1"
$for i in `seq ts.2 ts.120`; do
str=$str+" + map$i", done
I need this exact command, but in csh I have been playing with the
syntax and cannot seem to get it to work. I know I will switch out
"for i in" for like foreach, but the "str" command is not
interchangable, and neither is the "seq" command.
Any suggestions are greatly appreciated.
Aaron
