[GRASS-user] summation
goldneaa at onid.orst.edu goldneaa at onid.orst.edu
Thu Jul 12 15:51:55 EDT 2007
the script for adding 120 rasters worked.
set i=1
set str="r.mapcalc map=ts.1"
while($i <= 120)
set str="$str + map.$i"
@ i++
end
There is a limit to the command line around 383 rasters, so if I want
to add more rasters together than this I need to use a loop command.
What I have so far is
set sum=0
set i=1
set str="r.mapcalc sum=temp.1"
foreach raster ( `g.mlist rast pattern="temp.*" )
Basically what I need is to have a script that will take create a
running sum to add to the next raster file.  Like (temp.1 +
temp.2)=Sum.temp.  This first sum needs to be added to temp.3.  Then
the loop needs to take action so I can continue to culminate the sums
to be added to the next map layer.
Thanks for reaading,
Aaron
