[GRASS-user] Computing histograms inline with mapcalc?
Glynn Clements
glynn at gclements.plus.com
Sat Jul 14 09:06:29 EDT 2007
Shaun Walbridge wrote:
> We're looking at running a Monte Carlo simulation with our GRASS data,
> and one step I'd like to simplify is making histograms. Currently we
> use R, but given that our input rasters have millions of cells, it's
> time consuming. I was thinking that we might be able to use GRASS
> directly, since we're just doing many r.mapcalc calls.
> I see histogram.c, and ideally I'd like to just roll a custom r.mapcalc
> which adds its output to a histogram function, then write it out at the
> end of the program. My C chops are poor, but I'm imagining something as
> simple (in Python) as:
> hist = {}
> values = [0.1, 0.1, 0.2, 3, 5, 3, 0.1, 0.2, 3, 0.1, 0.1]
> for v in values:
> if hist.has_key(v):
> hist[v] += 1
> else:
> hist[v] = 1
> What would be my best bet for creating this histogram? Is hacking up my
> own mapcalc function feasible?
If you call G_want_histogram(1) before opening the output map, a
histogram will be generated automatically for any integer maps.
Also, running r.support.stats will generate the histogram for the
specified map.
