[GRASS-user] summation
Michael Perdue michael_perdue at yahoo.ca
Sun Jul 15 21:02:44 EDT 2007
Aaron is likely running into both problems. Mac OSX has a limit of
256 open files per process. I don't know how to change it but I'd
imagine it involves a kernel compile.
Cheers,
Mike
On 15-Jul-07, at 5:27 PM, Hamish wrote:
> goldneaa wrote:
>> There is a limit to the command line around 383 rasters, so if I want
>> to add more rasters together than this I need to use a loop command.
> You are probably hitting a maximum command line length of 4096 chars,
> not a max open map/file limit. (?)
