[GRASS-user] Has GRASS been used to create near real-time display of geomap?
Nithi, Nachi K (Karun) karun at research.bell-labs.com
Tue Jul 17 09:07:30 EDT 2007
Hamish,
Thanks for the links. Will look at it and report back.
Regards,
-Karun
-----Original Message-----
Sent: Tuesday, July 17, 2007 4:47 AM
To: Nithi, Nachi K (Karun)
Cc: grassuser at grass.itc.it
Subject: Re: [GRASS-user] Has GRASS been used to create near real-time
display of geomap?
Nithi, Nachi K (Karun) wrote:
> I am wondering whether GRASS has been used to create near real-time
> display of vector maps with a street map (of a state or county) as the
> background map (PNG map) and several layers of symbols on top of it.
> These additional layers can be, for example, movement of a fleet of
> vehicles (each type of vehicle as a separate layer). If we want to
> create vector maps frequently with several thousand points (or vehicle
> symbols) how responsive GRASS will be in terms of speed and memory
> usage. Assume that we want to use mysql as the database and that the
> map will be displayed on a web browser.
GRASS isn't really built for this, but is flexible enough to do it if
you really want. I hear QGIS is getting a real-time NMEA plugin, but
again it suffers the same problem of the task being well outside its
design intentsions. Better to start with something built for it like
GpsDrive or Kismet?
previous m.in.realtime_gps GRASS 5 real-time GPS display:
  http://grass.itc.it/pipermail/grassuser/2006-September/036438.html
http://lists.alioth.debian.org/pipermail/pkg-grass-general/2005-January/
000452.html
idea for real-time GPS display with GpsDrive using auto-refresh
background tiles produced by GRASS's d.out.gpsdrive in a sleep-loop:
  http://article.gmane.org/gmane.comp.linux.gps/1406
good luck,
Hamish
