[GRASS-user] raster region
Wed Jul 18 16:07:23 EDT 2007
goldneaa at onid.orst.edu wrote:
> Going  back to my question about about cutting out sections of maps.
> What I am looking for is being able to project a raster map of say
> temperature over the globe (180, -180, 90, -90), then I bring in a
> vector map of say New Mexico.  My projection at this point has the
> globe temperature data and a small vector map of New Mexico.  Is there
> a way to cut out a piece of that map leaving new mexico with the the
> temperature data over it, leaving behind all the rest of the global
> temperature data.  The directions for v.digit, I do not think quite
> does this operation.
	v.to.rast ... output=MASK
	r.resample ...
	g.remove rast=MASK
If a raster map named "MASK" exists, any module which reads raster
maps will automatically see nulls wherever the MASK cells are zero.
