[GRASS-user] Crash of King's build on v.buffer
William Kyngesburye woklist at kyngchaos.com
Thu Jul 19 13:56:02 EDT 2007
I just tried a buffer on bugsites in the Spearfish data - no
problems.  A simple fixed buffer distance.
details?  can you reproduce the problem on the spearfish data?  What
is the exact command you used?
There may be a crash report - check Console.app.  Dig into your home/
library/logs/crashreporter and see if there is something there for
v.buffer.
On Jul 19, 2007, at 12:27 PM, Brandon M. Gabler wrote:
> I just yesterday installed William Kyngesburye's most recent build
> of GRASS 6.3 (070714) for Mac OSX on Intel machine, and tried to
> create buffers around each vector in a dataset with only 8 sites.
> The program closes, and fails to produce the map. On an older build
> of 6.3, this process works fine with the same vectors, same
> settings, etc.
> I just wanted to alert folks to this.
> Brandon
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
