[GRASS-user] Crash of King's build on v.buffer
William Kyngesburye
woklist at kyngchaos.com
Thu Jul 19 14:55:32 EDT 2007
Looks like it never even made it out of the GUI to run v.buffer. Was
there a v.buffer crashlog? It may be a TclTk problem, not v.buffer.
If it happens again in the GUI (it may be random?), try immediately
again in the Terminal.
On Jul 19, 2007, at 1:34 PM, Brandon M. Gabler wrote:
> I tried the same thing on spearfish....works fine!
> I attached the crash report from today - I tried the same command
> twice, so there are two reports a mere minutes apart.
> This is the exact command I attempted:
> v.buffer input=LANL_Coalition_80plusRooms at SantaFeNF output=buffer
> type=point,line,area layer=1 buffer=2000 scale=1.0 tolerance=0.01
> I just attempted it again, and it did NOT crash...
> Seriously, I tried it twice earlier, crashed both times.
> Thanks for the suggestion....I need to remember to refer to
> spearfish for quality control.
> Brandon
> CRASH LOG::
> Host Name: brandon-gablers-computer
> Date/Time: 2007-07-19 10:21:37.395 -0700
> OS Version: 10.4.10 (Build 8R2218)
> Report Version: 4
> Command: wish8.4
> Path: /Applications/GRASS-6.3.app/Contents/Resources/bin/wish8.4
> Parent: launchd [1]
> Version: GRASS GIS 6.3.cvs (6.3.cvs)
> PID: 2946
> Thread: 0
> Exception: EXC_BAD_ACCESS (0x0001)
> Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000548
> Thread 0 Crashed:
> 0 libtk8.4.dylib 0x0b023ee5 RecomputePlacement + 337
> 1 libtcl8.4.dylib 0x0a06579e TclServiceIdle + 65
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
