[GRASS-user] Re: [GRASS-dev] gdal import an nodata cells
Michael Perdue michael_perdue at yahoo.ca
Fri Jul 20 14:31:28 EDT 2007
Ops... Looks like Geotiff does allow for storing no-data values. But
HFA (not too sure which format IMA is) and others don't appear too.
Question?
is float(nan) equal to double(nan)? If not, does gdal_translate
understand this when it converts a file stored as float64 to float32?
gdal_translate allows one to define what the no-data value is, but
how do I tell it to change the input no-data value to a different
output no-data value? IE, the no-data value in my surfer file is a
double precision nan, but I want the no-data value in my output
GeoTiff (float32) to be -32767. -a_nodata changes the header no-data
definition but does not change the values of the pixels that
represent no-data.
Sorry, It's not really a grass question but I thought I'd ask since
were on the topic and it's currently giving me headaches.
Cheers,
Mike
On 19-Jul-07, at 7:45 PM, Michael Perdue wrote:
> gdalinfo will show the nodata value if the file format supports
> storing the value in the header. So, for surfer, DTED, USGSDEM and
> such it indicates what the nodata value is but not for GeoTiff, IMA
> and such.
>> does gdalinfo show the nodata value? (I'm not sure if it should or
>> not)
> Mike
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
