[GRASS-user] g.mlist: order of numbers
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Mon Jul 23 11:26:43 EDT 2007
On Monday 23 July 2007 17:03:51 Martin Wegmann wrote:
> On Monday 23 July 2007 13:45:06 Markus Neteler wrote:
> > Martin Wegmann wrote on 07/23/2007 11:57 AM:
> > > hello,
> > > I have a script which creates so far n rasters with an analysis on
> > > different spatial scales.
> > > Now I want to apply r.series for an analysis of their trend but doing
> > > it fails because I haven't figured out, how to add all new images
> > > (name.1, name.2, name.3,...., up to name.n ) to a r.series command in
> > > the correct order.
> > > Theoreticall I can merge r.series and g.mlist as shown in the help
> > > pages but when I run g.mlist the order is: name.1, name.11,
> > > name.12,....
> > > It would be no problem adding $GIS_OPT_output.1, $GIS_OPT_output.2, ...
> > > by hand, but because the number of scales differ I had to adept it
> > > every time again.
> > > any hint is appreciated, TIA,
> > Martin
> > probably you have to fill with 0 to get the numbers right, using
> > something like
> > echo "1" | awk '{printf "%03d\n", $1}'
> > 001
> I added .00 to the numbers but unfortunately that did not work, I get:
> g.mlist type=rast pattern=$GIS_OPT_output*
> test.001
> test.0010
> test.002
> test.003
> test.004
> test.005
> test.006
> test.007
> test.008
> test.009
ah, sorry, just realized that I have:
test.0010
instead of
test.010
renaming test.0010 to .010 gives the correct order.
but I did not manage to get your example running, Markus.
my test.001 is "$1$, isn't it? So I have to replace $1 with my filename?
sorry, not a lot of experiences with awk.
Martin
> Martin
> > Markus
> > ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
> > ITC -> since 1 March 2007 Fondazione Bruno Kessler
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
